Hi! How can i create pipe segment through Dynamo? I found this in RevitAPI. I don’t understand - how it use?
Hi there,
Maybe this could help you.
Thank you! But this theme is about creating pipe. I need to create pipe segment:
There is my code:
As you can see - my problem is in “ScheduleId” now. Where i can find it?
Hi @catexis
You need to use the PipeScheduleType. Create Method which takes only 2 simple arguments : doc and a string to give it a name. Check Revit API help for more information. Second option is to use an existing schedule/type as you did with material.
I did a dynamo + python script to add sizes to an existing PipeSegment. I will post it on my blog today or at the end of the week : http://pythoncvc.net
Cheers
wow! I read your blog occasionally. Your works is great!
Thanks @catexis ! I’m glad that you appreciate it
Article has been posted yesterday : http://pythoncvc.net/?p=222 If your topic is answered, please refer my post as the answer. If not, I will post an example with PipeScheduleType.Create method soon.
Here is my script: PipeSegment_add.dyn Your script is add new string to existing table. My script is create new table.
Thanks for your work @catexis, it has been very useful for me.
Regards,
Can you post a link to the excel files that was used?
