Hi,I am fairly new to dynamo and would appreciate any help regarding this python script.
I have looked at previous posts related to this issue but cant seem to get this script working. Have a similar script for Ducts which works fine but could someone help get me over the line with this. Thanks
Use:
instead of IN[5]
Mby it helps
I can see you are missing the level id in the method you are calling. It should be level.Id and not LevelId
The code is correct, but you are inputting strings in IN[2] and IN[3] instead of the actual types.
Can you give me this script please?
