Trying to create multiple groups of multiple model elements?
Not sure where list.groupbykey helps here:
Hi
What do you mean with “groups”? Do you mean a revit group or do you mean that you want to “group” all the filled regions with a certain value for a certain parameter into dynamo lists?
Could you also your share Revit+Dynamo files?
Yep, Revit groups (not dynamo node groups), the process would involve select multiple items in revit and create individual groups. a good example when arraying something in revit by default revit groups those elements one by one.
GroupByKey is used to group items in a list. You need something like Group.FromElements from Clockwork.
You can do it like this. I also tried the Clockwork one, but it didn’t work for this instance.
GroupFilledRegions.dyn (18.6 KB)
pffff stupid me, I send you the old version. Didn’t save the graph after I resolved the issue…
Top notch work Joel, this worked like a charm
Thank you
