Create grading from feature line
I want to create a grading between a feature line and a surface, something similar to what is shown in the pictures below. The feature line is created in dynamo with the FeatureLine.ByPolyCurve.
I start the grade creation with the “_AeccGradingTools”, could i use this in Dynamo? I have tried to search the Civil 3D .NET API for a method that might help me, but I haven’t found anything.
Can I create a grading with Dynamo?
Maybe something like this?
Hi @magpies,
I think you are correct, the .NET API doesn’t expose any members for grading objects so I think you might be out of luck. Here’s an older post that was similar:
Thank you both for your answers.
My temporary solution is to have a arbitrarily placed feature line with a grading group already placed in the file, then use dynamo to change the feature line to the desired location.
Hi, i want to know how you can do it, because i’m trying to do the same, but i dont know where are the nodes, could you helpe me pleaase!!.
