This code generate Floor plans from Room Boundary
If the model contains Areas …
Can I make this code working with Areas instead of Rooms.
Yes you can…there are also nodes from different packages that can do this. If you want to do it in python it is also doable.
I presume you have not done any graph yet? If not please create one and if you are stuck post your image and errors and the community will help you.
Thanks for Reply
The only I need to convert the code in the link I provided above from Room to Area
What packages are these? I’ve done a search but couldn’t find any so far.
bump
