Create empty list with n amount of rows
I want to generate/create a list based on a given amount of numbers (integer of number). However I just seem unable to do so.
The result that I want is:
List
[0] empty
[1] empty
etc.
This has to be generated by a number.
Thanks in advance
List.OfRepeatedItems with an empty list as the item I put and the number you want as the other import.
Thanks for your fast reply, however this does not solve my problem.
I want an empty list that exists of 2 rows. Not an empty list that consist of two empty lists. What should be the item for this?
Each empty list is a row, not an empty list.
If you are looking for a different data type, you need to pass that data type. However Dynamo doesn’t have such a thing as an empty. Perhaps a null is what you are after?
if that’s what you’re looking for
it’s a lot of emptiness :wink:
cordially
christian.stan
Aahhh I supose a null is what I’m after.
How do you create that?
Type it in a code block. :slight_smile:
Note that null is a bad data type for downstream automation with Dynamo - it will cause errors in most nodes… what are you really after with the larger automation?
ahhh thank you!
Well I want to create an excel sheet, however the first column is 2 cells longer then the other column, so the second column needs to pushed 2 cells down in order to make both columns even long.
Null is the right data type then. Or an empty string. Both work in this context, but I would do so as the very last step.
List.InsertItemAtIndex would be how I would do this. Might need two in a row, or a List.Flatten with levels set correctly.
