Create elevations based on MULTIPLE scope boxes with Python
I came across this charm.
But i try to get it to work for multiple Scope Boxes. I think something in the Python needs to be change for that (?). I already fiddled with Levels and such, but it wasn’t that simple :sweat_smile:.
Script for Revit 2024_2.dyn (76.7 KB)
@c.poupin are you able to help?
Best to share a screenshot with what you have and what you’re seeing. If it’s just a matter of going from one scope box to many then you should just need another for loop.
Elevation markers are not “Views Dependent”, so I don’t really understand the request.
Who’s request? @c.poupin
I will post screenshots and the original Python :snake: tomorrow @Nick_Boyts
this question ↓↓
@c.poupin Sorry, that was a typo. I meant multiple Scope Boxes. Fixed that typo :sweat_smile:.
try to use zip() function,
Example: adapt this to fit the structure of your input lists.
toggle = IN[0]
lst_points = UnwrapElement(IN[1])
lst_modelPoints = UnwrapElement(IN[2])
lst_cropCurves = UnwrapElement(IN[3])
viewType = UnwrapElement(IN[4])
lst = []
if toggle == True:
    for points, modelPoints, cropCurves in zip(lst_points, lst_modelPoints, lst_cropCurves):
        for ind, point in enumerate(points):
            # rest of code
Thank you. Will have a look at that tomorrow.
@Nick_Boyts
Hereby the screenshot
Die orginal Python you can find in this topic.
When i use the original code i get this error
Node Name: Python Script
Package: Core.Scripting
Dynamo Version: 2.19.3.6394
Host: Dynamo Revit
Messages: AttributeError : '0, Culture=neutral, PublicKeyToken=b77a5c561934e08' object has no attribute 'ToXyz' ['  File "<string>", line 34, in <module>\n']
State: Warning
I am not sure if i made the right changes to your code @c.poupin
import System
clr.AddReference('RevitAPI')
import  Autodesk.Revit.DB as DB
from math import atan2
toggle = IN[0]
lst = []
if toggle == True:
        modelMP = modelPoints[ind].ToXyz()
        modelMPX = modelMP.X
        modelMPY = modelMP.Y
        cropLines = cropCurves[ind]
        l1 = cropLines[0].ToRevitType()
        l2 = cropLines[1].ToRevitType()
        l3 = cropLines[2].ToRevitType()
        l4 = cropLines[3].ToRevitType()
        elevationPT = point.ToXyz()
        elptRotate = XYZ(elevationPT.X, elevationPT.Y, elevationPT.Z+100)
        ln = Line.CreateBound(elevationPT, elptRotate)
        elevationPTY = elevationPT.Y
        elevationPTX = elevationPT.X
        combY = elevationPTY-modelMPY
        combX = elevationPTX-modelMPX
        ang = atan2(combY, combX)
        eleMarker = ElevationMarker.CreateElevationMarker(doc, viewType.Id, elevationPT, 100)
        ele = eleMarker.CreateElevation(doc, doc.ActiveView.Id , 0)
        ElementTransformUtils.RotateElement(doc, eleMarker.Id, ln, ang)
        crManager = ele.GetCropRegionShapeManager()
        newCurveLoop = List[DB.Curve]()
        newCurveLoop.Add(l1)
        newCurveLoop.Add(l2)
        newCurveLoop.Add(l3)
        newCurveLoop.Add(l4)
        cLoop = CurveLoop.Create(newCurveLoop)
        lst.append(ele)
    OUT = lst
    OUT = lst
Because i get the following warning
Host: Dynamo Revit
Messages: PythonEvaluator.Evaluate operation failed.
IndentationError : ('expected an indented block', ('<string>', 35, 9, '        modelMP = modelPoints[ind].ToXyz()\n'))
State: Warning
I hate doing it, but was fiddling with ChatGPT a bit (also out of curiousity) :see_no_evil_monkey:
The Elevation Markers got placed but face the wrong direction.
import System
# Inputs
toggle = IN[0]
points = [UnwrapElement(pt) for pt in IN[1]]
modelPoints = [UnwrapElement(mp) for mp in IN[2]]
# Normalize input format
if not isinstance(points[0], list):
    points = [points]
    modelPoints = [modelPoints]
lst = []
log = []
if toggle:
    for i in range(len(points)):
        pts = points[i]
        mps = modelPoints[i]
        for ind, point in enumerate(pts):
            try:
                modelMP = mps[ind].ToXyz()
                elptRotate = XYZ(elevationPT.X, elevationPT.Y, elevationPT.Z + 100)
                combY = elevationPT.Y - modelMPY
                combX = elevationPT.X - modelMPX
                # Create elevation marker and view
                # Define local rectangle in view plane (centered at origin)
                size = 100.0
                half = size / 2.0
                localPts = [
                    XYZ(-half, -half, 0),
                    XYZ(half, -half, 0),
                    XYZ(half, half, 0),
                    XYZ(-half, half, 0)
                # Get view direction and up vectors
                viewDir = ele.ViewDirection.Normalize()
                upDir = ele.UpDirection.Normalize()
                rightDir = viewDir.CrossProduct(upDir).Normalize()
                # Build transform from local (view space) to world
                basisX = rightDir
                basisY = upDir
                basisZ = viewDir
                origin = ele.Origin
                transform = Transform.Identity
                transform.BasisX = basisX
                transform.BasisY = basisY
                transform.BasisZ = basisZ
                transform.Origin = origin
                # Transform each point to world space
                worldPts = [transform.OfPoint(pt) for pt in localPts]
                # Build lines and curve loop
                lines = [
                    Line.CreateBound(worldPts[0], worldPts[1]),
                    Line.CreateBound(worldPts[1], worldPts[2]),
                    Line.CreateBound(worldPts[2], worldPts[3]),
                    Line.CreateBound(worldPts[3], worldPts[0])
                for line in lines:
                    newCurveLoop.Add(line)
                crManager.SetCropShape(cLoop)
                lst.append(ele)
            except Exception as e:
                log.append(f"Failed at index {ind} in group {i}: {str(e)}")
                continue
# Output
OUT = (lst, log) if toggle else ([], ["Toggle is off."])
When i do this they all face the same direction.
Getting there.
Only running into this problem and i am not sure what i am missing.
It works when i use the script for a single Scope Box.
They Elevation Markers Scope Boxes get greyed out on placement.
Dunno why. I guess something in de Python code?
Success!
import System
# Add Revit API References
# Document reference
# Inputs
toggle = IN[0]                                  # Boolean toggle to run
points = [UnwrapElement(pt) for pt in IN[1]]    # Elevation marker positions
modelPoints = [UnwrapElement(mp) for mp in IN[2]] # Model reference points
viewType = UnwrapElement(IN[3])                 # ViewFamilyType for elevation
# Normalize input format for multi-point runs
    points = [points]
# Execution
created_views = [[] for _ in range(len(points))]  # One list per group/scope box
if toggle:
        pts = points[i]
            try:
                # Get XYZ positions
                # Vector direction for rotation
                axis = Line.CreateBound(elevationPT, elptRotate)
                angle = atan2(elevationPT.Y - modelMP.Y, elevationPT.X - modelMP.X)
                eleView = eleMarker.CreateElevation(doc, doc.ActiveView.Id, 0)
                # Rotate the marker to face the model point
                ElementTransformUtils.RotateElement(doc, eleMarker.Id, axis, angle)
                # Add the view to the correct group
                created_views[i].append(eleView)
            except Exception:
                continue
# Outputs
OUT = created_views if toggle else []
I really didn’t want to resort to ChatGPT, but it got me to a solution.
Also learned you really need to ask ChatGPT the right questions and i really need
to learn Python still.
Great work @bvs1982!
Been popping in every hour or so to watch your progress. Kudos for sticking with it and showing us the process!
I couldn’t stand it that i was soooo close.
I really wanted it resolved so i could get it out of my head :sweat_smile:.
