Found this topic on the exact same subject. Tryed putting an transaction start node before the structural framing creation node and a transaction end node after the creation of these families… it kinda helps, but the graph is still glitchy…
I think that the problem is with the node StructuralFraming.BraceByCurve… Does anyone knows a way to do it through the API?
I managed to find the solution.
It was indeed related to the transaction node… It worked when i created every Structural framing family using a single instance of the node StructuralFraming.ByBrace
