Create Dynamo routine for drilling rock bolts in tunnels
Hi, I’m looking for creating a Dynamo routine for Autodesk Civil 3D 2024. I am not a dynamo user friendly. I need some to help with this even if will pay for it.
Scope of Work:
Automate the creation of 3D lines (rock bolts) perpendicular to the tunnel body (Corridor).
The placement should follow the tunnel profile (Corridor).
Allow placement of the bolts at a range of chainages along the tunnel alignment.
A working Dynamo script (.dyn) with user-friendly inputs (e.g., spacing, length, chainage range).
The Dynamo should allow me to:
-Choose the corridor.
-Specify the alignment or can get it from the selected corridor.
-Define the bolt pattern (centered / staggered).
-Set the spacing between bolts(3d lines).
-Input the length of the bolts(3d lines).
-Add all lines on a layer and label the layer with corresponding lines on the profile view. e.g. profile view at chainage 15, all lines on it will use Ch15-RB-001, Ch15-RB-002, Ch15-RB-003 and so on.
The bolt pattern:
Welcome to the Dynamo forum, @eng.amgad81 !
The forum is mainly for users to share advice and knowledge, and it is expected that users undertake the development themselves instead of relying on other users to do the work.
However, in your case, it seems that you need someone to do the work for you, so I recommend that you put your post under the Jobs category to get more attention.
