lucamanzoni san
Thank you for your consideration.
I was able to create dimensions well for me.
An error occurred because Clockwork Wall.Orientation node outputs Revit XYZ, but it was fixed with reference to the following forum.
Wall_Layer_Dimension_01.dyn (31.2 KB)
I am sorry for my lack of explanation, but is it possible to create dimensions without using model lines or detail lines?
Ideally you should be able to create dimensions only with wall elements.
Thank you.
