Create Cloosed Loop of Lines By points
Greetings,
I am trying to create a series of lines that form a closed loop using knowing points.
But, I cannot get a well-closed loop because the lines are intersecting with each other as shown in the shoot.
Is there anything I am missing?
Need to sort the point somehow before creating the lines ?
Appreciate the help and support.
You can use a library from post Solve salesman problem, Shortest Path through Points, by using Python 3 to sort point before create line
Shortest Path.dyn (35.5 KB)
I really do not know how to thank you, you give me the way
Although, I used this code:
import System
import sys
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append('%s\IronPython 2.7\Lib' % pf_path)
import math
import random
from cStringIO import StringIO
sys.stdout = StringIO()
def distL2((x1,y1), (x2,y2)):
    """Compute the L2-norm (Euclidean) distance between two points.
    The distance is rounded to the closest integer, for compatibility
    with the TSPLIB convention.
    The two points are located on coordinates (x1,y1) and (x2,y2),
    sent as parameters"""
    xdiff = x2 - x1
    ydiff = y2 - y1
    return int(math.sqrt(xdiff*xdiff + ydiff*ydiff) + .5)
def distL1((x1,y1), (x2,y2)):
    """Compute the L1-norm (Manhattan) distance between two points.
    return int(abs(x2-x1) + abs(y2-y1)+.5)
def mk_matrix(coord, dist):
    """Compute a distance matrix for a set of points.
    Uses function 'dist' to calculate distance between
    any two points.  Parameters:
    -coord -- list of tuples with coordinates of all points, [(x1,y1),...,(xn,yn)]
    -dist -- distance function
    n = len(coord)
    D = {}      # dictionary to hold n times n matrix
    for i in range(n-1):
        for j in range(i+1,n):
            (x1,y1) = coord[i]
            (x2,y2) = coord[j]
            D[i,j] = dist((x1,y1), (x2,y2))
            D[j,i] = D[i,j]
    return n,D
def read_tsplib(filename):
    "basic function for reading a TSP problem on the TSPLIB format"
    "NOTE: only works for 2D euclidean or manhattan distances"
    f = open(filename, 'r');
    line = f.readline()
    while line.find("EDGE_WEIGHT_TYPE") == -1:
        line = f.readline()
    if line.find("EUC_2D") != -1:
        dist = distL2
    elif line.find("MAN_2D") != -1:
        dist = distL1
        print "cannot deal with non-euclidean or non-manhattan distances"
        raise Exception
    while line.find("NODE_COORD_SECTION") == -1:
        line = f.readline()
    xy_positions = []
    while 1:
        line = f.readline()
        if line.find("EOF") != -1: break
        (i,x,y) = line.split()
        x = float(x)
        y = float(y)
        xy_positions.append((x,y))
    n,D = mk_matrix(xy_positions, dist)
    return n, xy_positions, D
def mk_closest(D, n):
    """Compute a sorted list of the distances for each of the nodes.
    For each node, the entry is in the form [(d1,i1), (d2,i2), ...]
    where each tuple is a pair (distance,node).
    C = []
    for i in range(n):
        dlist = [(D[i,j], j) for j in range(n) if j != i]
        dlist.sort()
        C.append(dlist)
    return C
def length(tour, D):
    """Calculate the length of a tour according to distance matrix 'D'."""
    z = D[tour[-1], tour[0]]    # edge from last to first city of the tour
    for i in range(1,len(tour)):
        z += D[tour[i], tour[i-1]]      # add length of edge from city i-1 to i
    return z
def randtour(n):
    """Construct a random tour of size 'n'."""
    sol = range(n)      # set solution equal to [0,1,...,n-1]
    random.shuffle(sol) # place it in a random order
    return sol
def nearest(last, unvisited, D):
    """Return the index of the node which is closest to 'last'."""
    near = unvisited[0]
    min_dist = D[last, near]
    for i in unvisited[1:]:
        if D[last,i] < min_dist:
            near = i
    return near
def nearest_neighbor(n, i, D):
    """Return tour starting from city 'i', using the Nearest Neighbor.
    Uses the Nearest Neighbor heuristic to construct a solution:
    - start visiting city i
    - while there are unvisited cities, follow to the closest one
    - return to city i
    unvisited = range(n)
    unvisited.remove(i)
    last = i
    tour = [i]
    while unvisited != []:
        next = nearest(last, unvisited, D)
        tour.append(next)
        unvisited.remove(next)
        last = next
    return tour
def exchange_cost(tour, i, j, D):
    """Calculate the cost of exchanging two arcs in a tour.
    Determine the variation in the tour length if
    arcs (i,i+1) and (j,j+1) are removed,
    and replaced by (i,j) and (i+1,j+1)
    (note the exception for the last arc).
    Parameters:
    -t -- a tour
    -i -- position of the first arc
    -j>i -- position of the second arc
    n = len(tour)
    a,b = tour[i],tour[(i+1)%n]
    c,d = tour[j],tour[(j+1)%n]
    return (D[a,c] + D[b,d]) - (D[a,b] + D[c,d])
def exchange(tour, tinv, i, j):
    """Exchange arcs (i,i+1) and (j,j+1) with (i,j) and (i+1,j+1).
    For the given tour 't', remove the arcs (i,i+1) and (j,j+1) and
    insert (i,j) and (i+1,j+1).
    This is done by inverting the sublist of cities between i and j.
    n = len(tour)
    if i>j:
        i,j = j,i
    assert i>=0 and i<j-1 and j<n
    path = tour[i+1:j+1]
    path.reverse()
    tour[i+1:j+1] = path
    for k in range(i+1,j+1):
        tinv[tour[k]] = k
def improve(tour, z, D, C):
    """Try to improve tour 't' by exchanging arcs; return improved tour length.
    If possible, make a series of local improvements on the solution 'tour',
    using a breadth first strategy, until reaching a local optimum.
    n = len(tour)
    tinv = [0 for i in tour]
    for k in range(n):
        tinv[tour[k]] = k  # position of each city in 't'
    for i in range(n):
        dist_ab = D[a,b]
        improved = False
        for dist_ac,c in C[a]:
            if dist_ac >= dist_ab:
                break
            j = tinv[c]
            d = tour[(j+1)%n]
            dist_cd = D[c,d]
            dist_bd = D[b,d]
            delta = (dist_ac + dist_bd) - (dist_ab + dist_cd)
            if delta < 0:       # exchange decreases length
                exchange(tour, tinv, i, j);
                z += delta
                improved = True
                break
        if improved:
            continue
        for dist_bd,d in C[b]:
            if dist_bd >= dist_ab:
                break
            j = tinv[d]-1
            if j==-1:
                j=n-1
            c = tour[j]
            dist_cd = D[c,d]
            dist_ac = D[a,c]
                z += delta
                break
    return z
def localsearch(tour, z, D, C=None):
    """Obtain a local optimum starting from solution t; return solution length.
    Parameters:
      tour -- initial tour
      z -- length of the initial tour
      D -- distance matrix
    n = len(tour)
    if C == None:
        C = mk_closest(D, n)     # create a sorted list of distances to each node
    while 1:
        newz = improve(tour, z, D, C)
        if newz < z:
            z = newz
            break
    return z
def multistart_localsearch(k, n, D, report=None):
    """Do k iterations of local search, starting from random solutions.
    Parameters:
    -k -- number of iterations
    -D -- distance matrix
    -report -- if not None, call it to print verbose output
    Returns best solution and its cost.
    bestt=None
    bestz=None
    for i in range(0,k):
        tour = randtour(n)
        z = length(tour, D)
        z = localsearch(tour, z, D, C)
        if z < bestz or bestz == None:
            bestz = z
            bestt = list(tour)
            if report:
                report(z, tour)
    return bestt, bestz
"""Local search for the Travelling Saleman Problem: sample usage."""
coord = [(p.X, p.Y) for p in IN[0] ]
n, D = mk_matrix(coord, distL2) # create the distance matrix
instance = "toy problem"
# function for printing best found solution when it is found
from time import clock
init = clock()
def report_sol(obj, s=""):
    print "cpu:%g\tobj:%g" % \
          (clock(), obj)
print "*** travelling salesman problem ***"
# random construction
print "random construction + local search:"
tour = randtour(n)     # create a random tour
z = length(tour, D)     # calculate its length
print "random:", z, '  -->  ',
z = localsearch(tour, z, D)      # local search starting from the random tour
print z
# greedy construction
print "greedy with nearest neighbor + local search:"
for i in xrange(5):
    tour = nearest_neighbor(n, i, D)     # create a greedy tour, visiting city 'i' first
    z = length(tour, D)
    print "nneigh attempt %i:" % i, z, '  -->  ',
    print z
print
# multi-start local search
print "random start local search:"
niter = 10
tour,z = multistart_localsearch(niter, n, D, report_sol)
assert z == length(tour, D)
print "best found (%i iterations): z = %g" % (niter, z)
sys.stdout.seek(0)
OUT = tour, sys.stdout.read()
Again I really appreciate your support.
