Hey there,
I’m trying to use dynamo to create calculated formula’s in schedules. I looked into the RevitAPIDocs, but I can’t seem to find a method for this. Does anyone know whether this is even possible at all?
Kind regards
Pieter
Hey there,
Kind regards
Pieter
Try this with a Formula ScheduleFieldType.
Good idea, but I get this error:
Exception: fieldType is not a schedulable field type
Parameter name: fieldType
If I use Count in stead of Formula, everything works fine.
Hi @pieter.lamoen and welcome, can you share/ post your code so we can help you?
This is my python code:
# Import libraries
import sys
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
# Import System Enum
import System
from System.Collections.Generic import*
# Define Current Document
# /// This is where the fun starts ///
# INPUT
schedule = UnwrapElement(IN[0])
# or input1 = UnwrapElement(IN[0])
# CODE
s_def = schedule.Definition
#TRANSACTION
s_def.AddField(ScheduleFieldType.Formula)
# OUTPUT
OUT = schedule
