Hi all I am trying to create bounding box around the elements with 1mm offset. The pictures are shown as below.
I am trying with below code but is somewhat different. I have extract the b and h values of column elements and I was trying to add 1mm to every corner nodes. But it the rotation of bounding box is the main Isuue. Please let me know how do I proceed ?
Thanks in advance.
You cant rotate boundingbox there are x y aligned but saw the other day @GavinNicholls had a work around…Think it was with cuboid
Hi @sovitek I want to know how to rotate solids or bounding box ? Because as we have nodes for elements but I want to rotate my solids or boxes. Please let me know
Ah, this old chestnut again…
Yes I rotate the geometry of the family instance by its rotation angle, bound that, then rotate the cuboid of that bounding box back the other way. As far as I know element aligned bounding boxes aren’t (easily) a thing in Dynamo. I believe you can use Revit API to assess Revit bounding boxes at a rotation if you reference a rotated coordinate system based on previous answers on these threads.
As for the 1mm offset, you’ll need to get the min/max bounding box points and move them to form a new one by shifting them 1mm in the X/Y positive (max point) and negative directions (min point).
In your case why not just intersect with a plane and get the perimeter curves
Something like this
This is slightly processive intense so if you happen to have a few thousands i would simply recreate the outer boudaries with the parameters
Thanks alot @GavinNicholls @sovitek I got the solution. As you motioned I extracted the max and min points and the gave diagonal offset of 1mm to both the points and then I recreated cuboid with min and max points. The script follows as below
Thanks for the suggestions.
Hi @Daniel_Hurtubise Thanks for your response. I’ll definitely give a try.
