ghl
August 15, 2017, 10:24am
1
hi,
I’m surching and try for an worklflow, to get surfaces from walls, they connect the room.
I would like to make a view for information of the material of the wall in every room.
Somebody every
tries??
Kulkul
August 15, 2017, 6:55pm
2
Are you trying to create elevation by room? This topic might help you
@Jason_Murray
Ive attached the definitions i use for generating Plans & elevations for Rooms. They are numbered 1-4 for the order i use them in. If you dont need the Floor plans of each room, ignore number 2.
Number 1 - Is not mine, got it from the Forums. It Centers the ‘placement point’ of each room to the center of the room
(Unless that would make it outside room boundaries, in that case it stays where the user placed it)
Number 2 - Again, taken from the forums and butchered a bit to suit…
