hi all,
could maybe somebody elaborate what could be the issue with installation of packages?
"Could not check integrity of package download?!
Revit 2021, Dynamo 2.5
hi all,
Do you get errors / warnings as well of you install the package ‘manually’?
Personally i stopped using the installer from Dynamo and allways install packages ‘manually’.
PS
With ‘manually’ i mean download the package (zip), unzip it in the correct folder. You can add (extra) folders, where packages are stored, in Dynamo.
Does this error reproduce?
Hi @Marcelo.Rak …I had the same situation on revit 2020, but not in 2021 ?? I thought it was something to do with letters æøå in username…the way i do it on 2020 its the same as @bvs1982 mention…download manually on the webside…
Hi Jacob,
what would “reproduce” mean in this context?
Yes, I always used installer, however after yours and @sovitek comment, tried to install manually and works perfectly.
So I suppose gonna just continue with that workflow. Thanks for help.
Does the issue persist after a restart of the cpu. If so can you grab a journal from the session and post back here? FYI @Michael_Kirschner2
sorry for late response. Totally forgot about this since I just manually installed and continued with the work. Tried to do it again and the issue persisted. Here is the error log…
Dynamo Log.txt (4.7 KB)
