As part of a larger script, i’m trying to get the inserts of some walls, deleting the wall and placering the inserts in a new wall.
I have tried making a smaller script wher i just copy the inserts and the place them again, and the deleting the original inserts. Just so i know the copy fuctions works as intended.
In the first image, i have frozen the delete part of the script. So i get the copy fuction to work.
But when its unfrozen (see image 2)
I don’t get the inserts corretly even thoughI have put a passtrough note, so the original ones should first get deleted after i have data from them. But it dosen’t seem to Work as intended
Hello…you could try set location or insert them again in new location with family instance by host and point from Spring…PS det ser dejligt ud med julegaver kl. 13.30
the problem is that I lose data from the inserts, if i choose to delete them later in the script. See pic 2.
So i can’t really place idencital instances in the same postions because of that?
It’s like i loose the data of the inserts instantly even tough a have put a passthrough node to make sure i get the data before they are deleted.
I havde tried placing this passthrough multple places, but with same result
Haha ja kunne godt se den lige var kommet med, men tænkte hvad fanden
this is actually part of another script, where I split walls by their layers, and make new walls of these.
Thats part is working fine now.
I then need to replace all the hosted elements back to these new walls. Thus i’m have created this small script to get that part working, because i hit the same problem about getting the data when the orignal walls was deleted
