I am trying to Copy/transfer project parameters from multiple links to current project file.
I thought it is possible to transfer project parameters as elements, although Revit does not allow to copy because conflict with other parameter with same definition.
Secondary option is to open the screen transfer project standards of Revit for each link file but it is a pain in the arse.
If you know any automation on that would appreciate it. Thanks
I get that result, that means nothing copied at the end
