Copy paste between two dynamo scripts
Hi Guys!
Simple question…How can I copy a smaller part of the script from one dynamo script and paste into another existing dynamo script? I have already tried to run the scripts under two different Revit files, but the usual Ctrl+C Ctrl+V command did not work. Any thoughts?
Many Thanks!
Peter
Ctrl+C and Ctrl+V should work as long as you stay in the same Dynamo session. So copy the nodes, close the current .dyn, open another and paste into that .dyn
This is it! Works.
Thanks for the quick feedback!
You may want to mark this as solved. Thanks :slight_smile:
