Copy Monitor Watched Elements
Hello all,
Is there a way to select an element that has been Copy/Monitored and its counterpart from the linked model? I looked on here and found some old post saying it was not exposed in the API. So I went to the API but only found BuiltInFailures.CopyMonitorFailures Class. My guess is that it is still not exposed but wanted to check.
Thanks,
Still not exposed as far as I know.
Thanks @jacob.small
Could you use the Element ID? Or does the copy/monitored element create a new instance and Element ID?
Could you then make a connection with the 2 in Dynamo?
Element ID’s do not match. It was a great thought though. I will post my work flow for going around this shortly. Its a bit of a mess right now.
Did you find a way to get a link between these objects? A GUID or something, which shows that these objects “are the same”?
I was never able to find a link. Sorry
