Hi all, I have a question.
I have Dynamo 1.3.4 installed (Revit 2017) and Dynamo 2.0 (Revit 2019).
Most of our nodes are done in the old version including those custom definitions.
I try to copy over the definitions from old to the new definitions folder.
The custom nodes now can be use but the library panel is showing as Blank. (see attached image below)
But when I delete the contents of definitions folder in the new version, library panel goes back to normal.
I try opening the custom node in Dynamo 2.0 and then use save as to save to the definitions folder and it works fine.
However, I have many custom nodes and doing this save as thing one by one is tedious.
can you guys suggest better solution?
