Copy a line with n repetitions
hi I want to copy this line repeatedly 5 times, for example. How can I do it? Thank you.
Instead of plugging 5 into the Geometry.Translate use a code block to create a range.
You can type:
1…n
into the codeblock and feed in n (this is 5 in this example).
If it’s going to be 5 each time then type 1…5 into the codeblock.
But the spacing…
What spacing do you want? You just said you wanted the line five times.
I would like to copy based on repetition and spacing the both
You’re gunna have to give me a little more info.
What do you mean by, “based on repetition”
Example could be useful, or a sketch.
I want to copy the line 5 times with a spacing of 15 meters between the lines.
I found it, thank you
That’s not going to give you a spacing of 15 between each line.
"How do I make 15 and 5 variable?
0…#n…p
Then feed in n and p (any letter or word will do, it’s just a placeholder)
Thanks a lot now i think it s working
Nice, please mark the answer as a solution :slight_smile:
