Copy 3 red points from line 1 to line 2
Hi Guys,
How to copy 3 red points from line 1 perpendicular to Line 2.
Best Regard,
Chris
Extend the curves and use intersect to return the points based on the second curve.
My problem is line1 and line 2 are not parallel and the length are not the same.
Hi @christopher.santosRK ,
maybe something like this
Cheers KS
Thanks! I appreciate it much.
Hello Kai! I encountered an issue where the script does not run properly if selections are made from right to left and from bottom to top.
hI @christopher.santosRK can flip the vector (reverse) to run both ways this will capture right to left /left to right … there will be a smarter way to capture the variants but it escapes me atm.
You can project either way by moving the distance to a point along the normal away from the curve and back double the distance as a line.
or probably plane at parameter and an intersect, should work in all direction
Hi Kai, Thanks a lot. It’s working now. Cheers!
