but i dynamo I have boundary of rooms from level 01 its 3400mm from survey point…
but the curves have Z=0 …also Point.ByCoordinates(0,0,0); is also in same plane as curves…why is not on level 00 same as survey point…
when you create a floor with dynamo on level 2
is it in revit on level 1?
if so
do you have 2 videocards on you’re computer
then thats the problem
2x nvidia k5000 causes that problem here
2x nvidia k2200 no problems here
It means that you can complete your initial post instead of creating new ones if there is no good reason to do so (such as describing two very different options with lots of details that could need different answers…). This makes threads easier to follow for other people and more consistent in general…
in first pictures you can see survey point in revit as 0,0,0 coordination…and I created room boundary in level 01 …its 3400mm up from survey point…picture one… all this curves have z=0 also point. coordination is created in level 01…
If I get height of level 01 its 3400mm …its only number…but if I create plane of level 01 the plane(level.plane) is 3400mm up from LEVEL 01??
I need generate for each level boundary that I need used for interselect with level plane…problem is if I select level 02,03,04 …how can I define plane of level?
