Coordinates based on the Survey Point
I am trying to obtain the coordinates based on the Survey Point. Which native Dynamo nodes can I use to obtain or transform these coordinates that I already extracted from the model (I understand that the coordinates I have obtained originate from the Internal Origin).
Can you post your graph?
Also this topic might give you some clues :backhand_index_pointing_down:.
This article may help you.
The coordinates doesnt match…
use this node from BriMohareb Pak
