Is the tag family you are using tagging the co-ordinates by orgin?
Probably using relative coordinates vs internal. Dynamo is always relative to the internal coordinates system vs the Revit one if it’s been adjusted.
The Genius Loci package has nodes which can correct points by coordinate system if needed.
Maybe you also have Rotation involved? Angle to True North?
If there is a Rotation Project North, can Dynamo be adjusted?
Yes, it’s bit tricky but I described something similar here:
