When i select pipes to convert them from one type to another that is happened “in the pic” is there a way to convert the type by a dynamo script
You would still run into the same issues with Dynamo. You’ll need to figure out what exactly is causing you to get these errors.
Related topics
| Change pipe type (Pipes and pipe Fittings) | 2 | 750 | November 17, 2021 | |
| Change pipe type -Error | 6 | 700 | December 13, 2021 | |
| Create Piping in Dynamo | 17 | 1798 | April 19, 2023 | |
| Change Pipe Type Query | 2 | 1451 | March 6, 2020 | |
| Script to create a pipe system using Revit Commands | 2 | 319 | December 16, 2024 |
