Converting Dynamo output to curves
Hi, I’m new to Dynamo, I have an issue looks simple but i couldn’t sort it out. I have a pattern of circles created with Dynamo. I’m satisfied now with the output but i don’t know how to convert it into detail lines or any sketch to be used in my Revit project. I can not edit the blue pattern created or even select it. Any suggestions
You can split circles and create detail lines. You can’t directly use circles. Similar topic is discussed here:
Actually the main purpose is to use the pattern in an extruded model in place panel.
and how to split the circle?
Just one way…
You can use Points generated at Parameters to create the Curves.
Hi, this is exactly what i wanted. By curve did it the right way.
