Convert the rvt file into the type of Autodesk.Revit.DB.Document
Hello everyone.
I would like to ask, is there a way to convert the rvt file selected by File From Path into the type of Autodesk.Revit.DB.Document?
Or is there a way to directly select a Autodesk.Revit.DB.Document?
Thank you.
Hi @b10705001F2HWP something here maybe…
Thank you! This method seems to be working!
But because the selected document is the link document of the current document, Applications.CloseDocument node seems to be failed. Is this a big problem?
Hi not sure i understand then, if it the link document, you already do it in your first image with "select.get documents
Yes, I originally used select.get documents to obtain the link document.
But some files will have multiple link documents, so I want to use File Path to directly select a specific file.
