Hello
I’m trying to move RVT linked models to a specific workset based on the files name.
I can’t seem to find a way to select a whole link using dynamo?
Any help is appreciated
Hi safwat,
if i understand you correctly you might be looking for “Select.GetDocuments” from archilab.
The node retrieves all linked Documents as Revit.DB.Document, the name as string, RevitLinkInstance and the path as string.
I hope that helps.
