Hi Everyone!
I’m trying to get the stairs path line on Dynamo. But, I can’t use the “ToProtoType()” attribute on Revit.DB.Line
Can someone help me?
Has resolved in topic.
How convert the line to a curve - Revit - Dynamo (dynamobim.com)
an instance of CurveLoop is a IEnumerable<Curve> so, you need to iterate on it to convert curves are inside this collection
import sys
import System
clr.AddReference('RevitAPI')
elem = UnwrapElement(IN[0])
elemsStair = [doc.GetElement(x) for x in elem.GetStairsRuns()]
stairPathCurvLoop = elemsStair[0].GetStairsPath()
OUT = [x.ToProtoType() for x in stairPathCurvLoop]
i’m trying to understand this.
stairPathCurvLoop is Type CurveLoop
the line:
iterates through the CurveLoop and converts each Revit.DB geometry to Dynamo. When i use this on my example, i still get the error ‘’’ ‘Line’ has no attribute ‘ToProtoType’ ‘’’
# Dynamo
import sys
from Autodesk.Revit.UI.Selection import *
app = uiapp.Application
dataEnteringNode = IN
view = UnwrapElement(IN[0]) # An element - should be an elevation
#Get CropRegionShapeManager from elevation
csm = view.GetCropRegionShapeManager()
#Get Crop Region shape
crshape = csm.GetCropShape()
OUT = [c.ToProtoType() for c in crshape[0]]
Hi, you need to import the ‘GeometryConversion’ tools.
Read this
