So I have a number (for example 5) and I want to generate a list with that number.
The list at the end should look as following
1
2
3
4
5
It seems like a pretty easy feat, however I am unable to come to a solution, can someone help me?
Thanks in advance!
1…n in a codeblock? Where n is your number
As @Marcel_Rijsmus mentioned, very easy in a Code Block
, or alternatively you can use the Range
node.
can do what solamour suggest. if you want the imput value to be diffrent the 5 write 1…x
x will be an input and you can input any value
