Convert Modellines into RoomSeperationLines
Convert_ines.dyn (7.9 KB)
Can I use this script to convert Modellines into RoomSeparationLines or AreaSeparationLines?
On Revit Docs I find something, but it is absultly cryptical to use
http://www.revitapidocs.com/2018.2/bb7da2a1-6a68-df2a-aacb-1d90c8a0f5b7.htm
2019-02-28_12h10_46
KR
Andreas
Tricky stuff :slight_smile:
clr.AddReference('RevitAPI')
clr.AddReference('System')
ModelLines=UnwrapElement(IN[0])
CurveArray = CurveArray()
[CurveArray.Append(i.GeometryCurve) for i in ModelLines]
Autodesk.Revit.Creation.Document
docCreation = doc.Create
sepLines = docCreation.NewRoomBoundaryLines(doc.ActiveView.SketchPlane, CurveArray, doc.ActiveView)
OUT = []
for i in sepLines:
	OUT.append(i)
What is the comment for AreaSeperatorLine, Can i do it also… i tried just to replace Room by Area, but it isn`t so easy.
Thats realy a step forward. Because my final wish is to convert dynamo curves into ! I will post it soonconvert_dynamo_curve_into_RoomSeparetor.dyn (39.1 KB)
Convert or create new? Clockwork has nodes (and python) for creating.
The workflow is following:
I have a contur of a building, it is a polyline. I link this .dwg - each floor in Revit, level by level.
I would like to “convert” these lines (linked lines) to a “RoomSeperationLine”
The collection works very well!
Need I a “retrace-workflow”? How would it be?
