Hi all,
I have seen online several scripts that create room elevations from a given room. In my current company, we normally work with sections to create room elevations - which gives some advantages when the rooms are complex, as you can split the section and show the section cut through the legend plan. I was wondering if there is a way to transform an elevation view into a section with dynamo, so the section as outcome would cut where the room elevation cuts and show the same elevation extent as the room elevation.
Many thanks, in advance.
