Hello there,
I’m trying to place a custom generic element that I’ve created in the model using Dynamo. This model is always placed at the intersection between a wall and a column. Now I’ve already found a way to do this but there is a problem. The orientation of this element is important and it has to be placed similar to the picture I’ve attached here. Since there might be multiple walls connected to a column on different sides, is there a way to modify the orientation of this element according to the column face it’s being connected to? or maybe somehow setting a default face for the element so that it always connects to other elements via that?
is your Element facebased? or workplane? what does it cover? walls?
Do you have any try in Dynamo? Which revit version,…
KR
Andreas
the element is wall-based (which I guess can also be created as a generic model but still has to be placed at the intersection). It covers wall yes. and I’ve tried using dynamo for Revit 2019 but I just don’t know how to approach this issue exactly.
