I’m trying to connect two associated points with lines. The points are located on two surfaces and defined in different lists. When I use “Line.ByStartPointEndPoint” for the first indices of each list, it seems like the rows are shifted with respect to each other (see picture 1).
When I try to connect all the points by simply plugging the two lists respectively into startPoint and endPoint, it get’s messy (see picture 2). I’m thankful for any suggestion you might offer!
Thnks for the suggestion, but when I reverse the one list, the line just pops from the one corner to the other, as shown in the picture. If I could “flip” the coordinates, or inverse them somehow, I think it could work.
I’m sorry, but unfortunately I’m a new user, so I’m not allowed to upload files, only pictures, don’t know why but I get an error message when I try to upload the dynamo file. But the whole picture looks like this:
Thanks for the script edit, it certainly made it less messy and it now seems that each associated point connects in the same plane/height, but there’s still some problems as you can see in the picture. I think the “index pairs” of each list is now correct, but the problem is that the points in surface 1 starts at the bottom left corner (looking from the outside-in) while the points in surface 2 starts at the bottom left corner (looking form outside-in), which means overall surface 1 starts counting points from the opposite side with respect to surface 2.
