I have an Excel-sheet with a list of IfcGUID’s (several hundreds) and a list of Values that is connected to each IfcGUID.
What is the fastest and robust algorithm (node’s and sequence) to match that list with IfcGUID’s in the Revit-file. And then write the correct values accordingly?
Note! Assuming that I have the IfcGUID on the instances in the Revit-file. This is achieved by the setting (store IfcGUID in model when export to IFC).
can you post a picture of what excel sheet have ?
another question, does this excel sheet made from this Revit file previously ?
Hi, the workflow is:
- Export to IFC, from this Revit-file (IfcGuid is stored on each instance)
- IFC-file is used in another software that generates a value
- That new value would be nice to write to the same instances in Revit.
The Excel-file has basically two columns: IfcGuid and Value.
The only thing that is bothering me, is how to make a “look up” algortihm that matches IfcGuids and writes corresponding value.
can this software include element ID in this excel sheet ? it would be the perfect match
Nope. That other software only use IfcGUID. but if I had the element-ID, how would the script look?
you can match between element by their ID’s in different ways, dictionary nodes one of them,
if you could give upload a sample of your work it would be great to help you
Good morning,
Did you manage to solve this? I have the same situation…
We have an excel file with a number of Walls and Rooms containing fire-rating information. Not all of the Walls and Rooms have been classified.
We need to establish a link based on the GUIDs of the elements…
It’s been a while since I’ve used Dynamo, and can’t seem to remember how we might solve this problem.
Many thanks for your help!
Many thanks,
I’ll give this a go
M
