Why is the delete output 72 and not 8?
Is a filled region made up of 9 items?
This is common behavior when deleting things.
For example, delete a view and see how much deleted sub elements you get then:
yes… but as I asked… WHY?
Probably the boundary lines. Weird though! I dont believe if you use the API method it works that way so it might be built into the node that way to report sub elements as well.
Certainly an unideal degree of reporting for verifying element deletion count vs totals.
@Alien maybe try my element.delete node in Crumple which has exposed Python also if you want to see an alternative that doesn’t return sub elements.
Yes think so…ut how do your node handle it ? as if i look at genius loci it seems it do the same…if i use archilab it just give a bool …true or false…but think its actuelly do the same as well
I send out a true/false list that you can mask afterwards using filterbyboolmask to get the failing elements.
I have a try/except it goes through to catch the failures.
Here is an interesting example that shows that deleting an element sometimes is the only method to get access to the sub elements.
