Concatenate using Dynamo / Read CSV file family editor
Hi, I need help with a Revit family problem:
I want to concatenate the values of two parameters, “ConcreteClass” and “BondConditions”, in a family, and save the result in a third parameter, “Key”. In Excel, this would look like CONCATENATE(ConcreteClass, "_", BondConditions). Then, I’d use a lookup formula to match this “Key” value with a CSV file and return a corresponding value based on “Rebar Diameter”.
Since Revit doesn’t allow concatenation in family parameters directly, I thought about using Dynamo. My goal is to use Dynamo to concatenate the values and update the “Key” parameter, or alternatively, read the CSV and directly return the value based on the combination of parameters.
I’ve tried using Dynamo helped by AI, but I can’t get FamilyDocument.GetParameterValueByName to work.
Any ideas how could I solve this?
Thanks in advance.
Hello @joaoj and welcome :wink: …for get parameter value in a family document, you could try as here
hello,
I would ask why is there a requirement to duplicate information in the family? Revit has the ability to combine values in schedules and tags which will be dynamically updated
This is true, but with Revit schedules you cannot export the parameters first, and you also cannot set a shared parameter
If you set a shared parameter in the family and set the same one in project parameters you can schedule them from the family.
