Comparing Point coordinates with Space coordinates
Hi all,
i hoping someone can help me finish this dynamo script. @Steven @Kulkul
im trying to isolate any wires/curves that are in more than one room. so that i can apply a filter to it so it displays as a dashed line rather than a solid.
i was planning to just add a value to the comments parameter and use a filter to change its display
i followed this topic to get somewhere near…
https://forum.dynamobim.com/t/is-point-in-list-inside-a-bounding-box/8968/15
Wires.rvt (2.6 MB)
Circuits across spaces.dyn (11.6 KB)
can anyone suggest a way i can get a list of wires that cross more than one room?
Thanks,
Dan
You could use:
To check if your boundingbox around your curve intersects the boundingbox around your room, this will negate you only looking at the endpoints.
Thanks Jonathan!,
this seems to have got me closer, i now have a count value on the rooms the wires cover.
so if its a true more than once then it cross rooms.
do you know a way i can isolate the wire to push it into the set parameter node?
Thanks!!
You could use something like a boolmask to filter out the relevant values as it is your elements you need to feed the “setparameterbyname” node (the node will not know the values 1,1 and 2 :slight_smile: )
Have a look here and get inspired:
Thank you again Jonathan!!
it working perfectly now.
i added the bool mask node and a second one to reset the values back if the wires change back to 1 space.
now to see if works on a large project! :grinning::+1::+1::+1:
You’re welcome :slight_smile:
If a comment solved your problem please mark it as the solution for future reference.
