I have collated a list of Wall Type widths and wish to compare against a small list of desired widths and return via boolean filter mask the applicable wall types only. I think l am nearly there, but it is currently returning the incorrect via the mask, yet on a single basis obviously fine. Any thoughts?
You can filter out Wall Types (or Wall Instances with subtle changes) with allowed Wall Width this way:
Many thanks for your reply.
Looks great.
My scenario is similar, but different. I have a list of widths (calculated), which l require to be cross-referenced against pre-existing Wall Type widths. However, what is being returned is not correct. Note, no walls are modelled at this point.
I have attempted to introduce your suggestion where l believe is applicable for my scenario.
From what I can see I think you need to make the list structure of the pink and the azure node the same. I would try to flatten it to match
I shall look into that now David. Many thanks for your time and patience.
Hi David,
That helped.
Now for wall placement, correlating order of original curves and placing the appropriate wall type relating to width per location.
I can get it to place all the walls, however, they are not in the correct order upon placement. Dare l ask any thoughts?
Resolved workflow.
