Combine several Parameters
Hello everyone, I would like to combine the values of several shared parameters into one. That worked so far down to the last value. I am grateful for every input.
@Bato Add a List.Flatten node after the Code Block and remove the @L1 from the SetParameterByName node
Hallo Thank you very much for your answar, i tried it, but it diden’t help.
Remove the List.Create node
OR
Flatten all the nodes before you send it to the code block
Hello AmolShah, :grinning:that helped. Thank you very much for your help.
