Is there a way to get both the room name and the room number combined and then into a furniture item parameter ?
So far, I can only get either the room name OR the room number rather than both the room name AND the room number combined
My progress so far in screenshot
I think I am making an error with list.combine somehow ?
Thanks for the response Christian,
How did you create that custom code block ?
you can make the variable name simpler (you should not take specific names for your variables (example; true, false, for, curve …) ) if you want, you forgot the + between Name_value and “-”
double click in the graphic area or code in the search field
edit
you can also avoid cascading the getparameters (it remains a choice)
Cordially
christian.stan
Hello…here is another way
