I have 3 lists that I want to combine, and include all possible combinations.
List 1: 0, 1, 2, 3, 4
List 2: 0, 1
List 3: A, B, C, D, E
I want the new list to be
0, 0, A
0, 0, B
Etc.
I tried in a code block a+ “,” + b + “,” c
but this did not list all possibilities,
For simplicity sake I reduced the length of the text that is being combined.
Yna_Db
October 9, 2017, 8:27pm
2
Thanks but i have searched a ton of threads and even those have not gotten me the desired result.
Yna_Db
October 9, 2017, 8:53pm
4
Try List.Combine + List.Join as a comb, both nodes should have the same number of list inputs.
Or see this thread:
Am trying to merge two list in the order displayed below. Any help will be appreciated.
[image]
I tried this and it does not get the desired result. I dont want sublists i want one list with each of the 3 other lists separated by a comma and with all possible combinations of it.
You need to look into level syntax and use the appropriate levels.
Maybe take a look at replication guides:
