Combine multiple Filled Regions
Good day,
I would like to combine selected Filled Regions into one (e.g. below). I know that it sounds a bit complicated to make it work. But is it possible at all? If not, do you know any workarounds? Thanks.
Hello @zalgirietis.minde …probably something here could work in your case…my graph is very rough but could be a start…I use archilab and clockwork…good luck
Nice, here is a similar approach to @sovitek one, but with a different technique to get the final shape.
It is creating solids but still works pretty fast. I thought this gif was fun.
FilledRegion
Thank you guys! I will check both of your solutions and get back to you!
Hello! I am attempting to use this script to combine filled regions, although the figures I am trying to connect are not correctly connecting from one point to the other, do you have any idea why this might be?
This is an example of the results I get when using this script
Thanks, I’m finding out
