First, I want to combine two lines to be a spline.
Then, I want to find out the endpoint of each spline.
However,I cannot figure out the correct answer.
I would appreciate any advices, thank you.
I want to use Line ABC Endpoint to match Line DEF Startpoint in order to combine two lines into one spline, but the answer is wrong. Find out Spline endpoint.dyn (18.8 KB)
