I want my column on level 1 but it is located on level 0. How do I get the column to the right level?
Hi @s163803,
Your curve must be in the correct ‘Z’ coordinates. Right now you are say the first point ‘X’ is located at datum 0 (Z=0), The top of the column is 1000 from 0 (Z=100).
You have assassinated the column at level 1 but the column top and bottom can be place anywhere along the Z axis relative to Z=0
You will need to adjust your ‘Z’ coordinate as follows:
x = (0,0,5000)
y = (5000,0,6000)
Hope this Helps.
Hi @cescobido
It works but… what does the Level option even do then?
It seems like the model does not change though another level is picked.
