<pre class=“tw-data-text vk_txt tw-ta tw-text-small” dir=“ltr” style=“color: #212121;” data-placeholder=“Traduzione” data-fulltext="">
<pre id=“tw-target-text” class=“tw-data-text vk_txt tw-ta tw-text-small” dir=“ltr” style=“color: #212121;” data-placeholder=“Traduzione” data-fulltext="">I create a wall in revit and then I select
In Dynamo run - > does not change color - > why ??
Thanks for your cooperation
upload image dynamo
Hello Alex Volt,
I think all connections are not made to Color.ByARGB. Can you connect a, g and b value and run the graph again.
We have sample showing this scenario. Go to Help> Samples> Revit> RevitColor. (you need to open revit project file from C:\ProgramData\Dynamo.7\samples\Revit\DynamoSample.rvt )
Let me know if above solution doesn’t work for you.
BTW, which build are you using?
Thanks,
Ritesh
Thanks Ritesh Chandawar
With the example you have shown it works … but with the example above comes the error
… And yet it is the same as yours … I can not understand
Hello Alex Volt,
Which are you using? (you can get the build number from Help>About)
Thanks,
Ritesh
Thanks Ritesh
Use the version 0.7.4.3143
I think the last
Regards !!
Alex
