Color - how to get channels from overrideGraphicsSettings
The reason why you are getting -1 is because the colours aren’t valid.
You could try this. It gets all the filters assigned to each view and then gets the filter overrides projection line colour and returns a Dynamo colour object if its valid:
#Copyright 2016. All rights reserved. Bimorph Consultancy LTD, 5 St Johns Lane, London EC1M 4BH www.bimorph.co.uk
#Written by Thomas Mahon @Thomas__Mahon info@bimorph.co.uk
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import Color
#Import ToDSType(bool) extension method
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
views = UnwrapElement(IN[0])
colList = []
for v in views:
	filters = v.GetFilters() # Get all the filter ids
	rgbList = []
	for f in filters:
		filterObject = v.GetFilterOverrides(f)
		col = filterObject.ProjectionLineColor
		if col.IsValid:
			rgb = DSCore.Color.ByARGB(255, col.Red, col.Green, col.Blue)
			rgb = None
		rgbList.Add( rgb )
	colList.Add(rgbList)
OUT = colList
