I want to color the pipe according to the Offset value.
For example, if pipe’s offset value is -500: Blue, if pipe’s offset value is -300: Magenta.
A list is made by the offset parameter among the elements selected in the Pipe category as follows. I want to define a color by coding that classifies by each offset.
Hi @ikek102030,
Welcome to the Dynamo community.
My recommendation would be to first try using BIM One’s Color Splasher add-in.
https://apps.autodesk.com/RVT/en/Detail/Index?id=5056644120649615847&appLang=en&os=Win64
But if you are looking for a Dynamo solution, I would do something like this:
- Find Unique Values
- Create Dictionary with Offset as Key and Color as Value
- Get values at key
- Set color
Thank you for your nice answer, @AmolShah!
I just started Dynamo, so I try to make program that use Dynamo as more as I can.
So, I tried your Dynamo solution.
But It doesn’t work.
Here is my Dynamo code.
I stuck in Dictionary.ValueAtKey. What is cause and how to solve it?
Thank you so much.
Hi @ikek102030 …could it help you to round the number so you dont have decimals
Thank you for your helpful suggestion, @sovitek.
Thank you for answer, @Deniz_Maral.
I tried your answer and it works!
I forgot that dictionary has key and value.
Here is solution Dynamo code of my question.
Thank you guys.
