Hi Friends,
is the any python code or node to collect the visible rebars in the current view which located inside the crop reigon.
Any help we be appreciated.
Thanks in advance
Hi Friends,
Thanks in advance
just use a Collector, active view
# 🎯 get items
elements = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
With this example, I have (4) pieces of rebar in the project. (3) are in the active view with only (2) of them visible in the view.
With the code block you have to make the view active before executing the script.
The “All Elements of Category In View” node will pull only the visible rebar in the inputted view. The view does not have to be active. And as shown, if you don’t provide a view, it pulls all of the rebar in the entire project.
@staylor , Thanks for your response.
I tried your way but the isuue is it collect all the visible rebars in the view even the ones outside the crop region of the view , So I am looking to collect only the visible rebars inside the crop region.
Thanks in advace
this method will collect all the rebars even the ones outside the crop region
That’s weird, because as my example shows and when I tested, the code block and the node (with the view specified) only collected the bars that were visible and inside the crop region. (1) bar is outside the crop region. (3) bars are inside the crop region, but only (2) are visible. Not sure why it pulled all rebar with your project. I will have to defer to others for insight. Sorry
a work around can be make a selection…
#đź”· PickElemnetsbyRectangle
selected_elements = selection.PickElementsByRectangle('visible rebars')
OUT = selected_elements
yes ! you have to set up your modules,
look
from Autodesk.Revit.UI.Selection import Selection
selection = uidoc.Selection #type: Selection
@Draxl_Andreas I got your point,
but your way force the user to make a selection when i am looking for collecting all the visible rebars inside the crop region automatically.
Do you have any suggestions.
Thanks in advance
make sure “crop view” is on
@rajeshjamariya16 , Yes i am pretty sure that the “Crop View” is On.
here a workaround if the cropshape of view is set
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def get_elem_in_view(view_plan, lst_BuiltInCategories = []):
catFilter = ElementMulticategoryFilter(List[BuiltInCategory](lst_BuiltInCategories))
elements_in_view = FilteredElementCollector(doc, view_plan.Id).WherePasses(catFilter).WhereElementIsNotElementType().ToElements()
# filter and fix list by cropRegionManager.Shape if is set
cropRegionManager = view_plan.GetCropRegionShapeManager()
if cropRegionManager.ShapeSet and view_plan.CropBoxActive :
temp = []
lst_CurveLoop_shape= cropRegionManager.GetCropShape()
solid_view_crop = DB.GeometryCreationUtilities.CreateExtrusionGeometry(lst_CurveLoop_shape, XYZ(0,0,1), 0.1)
topFace = next((f for f in solid_view_crop.Faces if isinstance(f, DB.PlanarFace) and f.FaceNormal.IsAlmostEqualTo(XYZ(0,0,1))), None)
if topFace is not None:
for elem_instance in elements_in_view:
if isinstance(elem_instance.Location, LocationPoint):
all_End_xyz = [elem_instance.Location.Point]
elif isinstance(elem_instance.Location, LocationCurve):
all_End_xyz = [elem_instance.Location.Curve.GetEndPoint(0), elem_instance.Location.Curve.GetEndPoint(1)]
bbx = elem_instance.get_BoundingBox(None)
all_End_xyz = [(bbx.Min + bbx.Max) * 0.5]
# compute ray fro each point and check the Intersection with TopFace
if all(topFace.Intersect(DB.Line.CreateUnbound(pt, XYZ(0,0,1))) == SetComparisonResult.Disjoint for pt in all_End_xyz):
pass
temp.append(elem_instance)
# replace init list
elements_in_view = temp[:]
# release geometry
solid_view_crop.Dispose()
return elements_in_view
view_plan = doc.ActiveView
OUT = get_elem_in_view(view_plan, [BuiltInCategory.OST_StructuralColumns])
@c.poupin , You always amaze me, As Usual
Many Thanks, Boss
Hany William.
